Hello warm weather freaks...
After some suggestions for where to get tyres and wheels (in canberra or syd)
for my R33.
If you know my ride, I have to get some power down at the rear, What width do tyres go to ? I'm looking at 18' or 19' and can see around the 8 / 9s and 9.5 -
are there 10s or higher etc (just asking)
Thanks for your help
Cheers
Goldie
https://www.sau.com.au/forums/topic/239407-tyre-rim-suggestions/
R33 Gtst's can accomodate up to 9.5 - 10 inch wide rims pretty easily under the rear (assuming that you get the right offset), if you are having trouble with traction try choosing a tyre with a better compound / traction rating over just going wider.
If you have a really wide sh_t tyre for example it wont help you get more traction over a really good tyre in a slightly narrower size, most of your traction comes from having a really good tread design and compound and a really well built tyre casing.
My suggestion, if you want it to look really good and get great traction is:
18 x 9.5 +40 - +42 offset with 265/35R18 Federal 595RS-R rear
and
18 x 8 +35 - +38 offset with 235/40R18 Federal 595RS-R front
Speak with the boys at Trojan Motorsport in Mitchell and they can organise some really sweet lightweight Jap wheels or Jax Fyshwick if you want something a bit cheaper (but not lightweight Jap wheels) to get them locally.
I hope this helps :D
yeah i got those federals on my car they are saweet
as for rims...have a look around...really worth trying to find somewhere that can do a genuine jap rim as the enthusiasts will pick it and id rather a comment like "nice rays" than "nice chromies" makes you know your car is appreciated by the right people :D
i'm currently trying to find some genuine equips for mine. i think thats what the guy of here (cant remember name) with the chaser has...man they are hot rims
but yeah...deff federals.
as for rims...have a look around...really worth trying to find somewhere that can do a genuine jap rim as the enthusiasts will pick it and id rather a comment like "nice rays" than "nice chromies" makes you know your car is appreciated by the right people :banana:
yeah thats what he has, he is exsitenz (or similar)
tis I.. yea genuine japanese wheels are the shit... nothing suits a JDM car better than JDM wheels.
also, i think you will be lucky to find a local wheel place that will have over an 8inch wide rim, i think the law only allows 7.5 or something along those lines so if you want anything thicker you will have to get it either from japan or second hand off someone who got it from japan like i did
my wheels are Work Equip 18x8.5+28 225/40 rubber on the front and 18x9.5+41 265/35 rubber on the rears.. looks tough.. love it
Edited by Ex!$t3nZ
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
