The car was bought completly stock, clean and babied 3 years ago with 101 000 highway kms on it and has since travelled about 19 thousand ks mildly modified.
The engine and driveline are in outstanding condition and have always been looked after (if i cant see through my oils they dont stay in the car).
Its freakish performance in this mildly modified setup is a testiment to the great condition of the car. I can also show you the standard cams that at 105 000 look like brand new.
I have no problem will taking you for a drive to prove it. just dont dob me in haha
However, unfortunatly the body has very slightly mismatched paint from a professional repair, 3 small dents and some scatches some of which from vandalism and would benifit from a good polish or even a respray but thats really the only thing seperating it from being a great car.
Im selling the car this cheap purely because i no longer have time to get a RWC.
The car is in Rockhampton QLD undercover and has been for the last year. Im deciding to sell it now as im preparing to buy a house
NO TRADES SORRY this was my second car ohh and ive since cleaned the car out inside so no more crap on the floor
December 2001 S15 200SX
6speed manual
Brilliant Blue
X-force 3inch Stainless Turbo Back exhaust
600x300x76 FMIC
ORC 409 series clutch and Flywheel
Tomei stage One Cams
Tomei Rocker Arm stoppers
Sportmaxx 18x8.5 18x9.5 inch rims with falken rears and hankook fronts
Drift Pod
Modified BOV so it doesnt bleed boost (intructions came with the tomei cams)
Cruise control needs the cable fixed. worn through thats how much it was used on the highway!
crappy kenwood mp3/cd player
Call Andy on 0438141442 or post on here for any further questions. No silly offers please as i believe im selling the car cheap enough as it is
Im also selling parts that never made it on the car brand new but out of the boxes
NEW BLITZ DTT DC-II turbo timer with built in boost gauge. its the best one $140 SOLD
NEW PIVOT SPEED METER V $90
NEW PIVOT 3stage SUPER SEQUENTIAL SHIFT LIGHT PRO $90 SOLD
NEW GREDDY SR20 LARGE CAPACITY SUMP $400
ALSO STANDARD (great for compliance)
FULL EXHAUST $100
AIR BOX $30
SIDE MOUNT COOLER $50
STOCK WHEELS STRIPPED AND PAINTED BLACK $offer
STANDARD CAMS $offer
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
