dam i would off love to come kuitpo is that near the forest there? ~mushrooms anyone lol!
but i have my little Nieces Christening that day so i wont make it sounds like it would be a load off fun.
Edited by R334door(s2)
  • Replies 101
yeah i know what its like with organising things. i used to organise a few car things for a while, and yeah no one shows regardless on the interest shown. i guess its just the whole car scene in general. always talking about what they are gona do to their car, which never happens. anywho.. just checking my exam timetable and ill sus out if im 100%, ill also try to con a few other people into coming.
well here's how it is on my end! i'm most likely going and same as 2 other guys! but this weekend i'll be asking all the boys if they want to go so i can see how much i'll need for the deposit, and it'll be deposited next week
Edited by nos man
Jugz has now deposited (but it hasn't shown up in my account yet).
JDM32
Craig 33
Bunny
All said they would deposit, but haven't yet. Cmon guys - I have to pay the paintball people the deposits this week.
I also have at least 3 of my mates confirmed.
yeah mate, get your deposit to me asap.
If you are still not 100% then you can rock up and pay on the day - but I will have to pay the minimum number deposit out of my pocket if I don't get enough to cover it - which I would rather not do ... just transfer me the $10 already :cheers:
Just keep them coming mate. If people put down a deposit, then they are MUCH less likely to pull out closer to the event or be too lazy to show up. The more deposits, the better. Plus it gives me an idea of how much bbq stuff to buy to cook for lunch.
sorry mate, busy sunday (starting to get to the xmas drink season) otherwise i would come out.
pitty rec has moved otherwise we could shoot him in real life not just on the net LOL
good luck / congrats on getting this all sorted. been a while in the planning
bah, what Xmas function can you possibly have at 9am on a Sunday Nick? You could be out of there by 12pm too - so lunch isn't even an excuse. Cmon mate harden up - I am busting to shoot you :P
Yeah, lucky Rec is in Paris atm .... have you been following his blog and pics? Very interesting reading! Check it out here (click) if you are interested.
its more the one the night before i'm thinking about. i'm not planning on being conscious on sunday LOL
been seeing bits and pieces of his trip over the last few days
Edited by Whiplash
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
