For sale, Electronic Boost controller + LCD Hand controller + Digital fuel adjuster + Intercooler water spray controller + Performance electronics handbook which explains it all.
These are all Jaycar kits which I purchased then sold my car, I paid around $300 which is already cheap considering these same items could cost $1000's with big brand names I am looking for only $199 delivered anywhere is Aus.
Thank you.
  • 3 months later...
Hi,
I have never installed them, but I have heard they are very good, and have been popular with other members, I remember a while back there was a couple of group buys on them if you want them I can do them $150 + $10 delivery.
Thank you.
Here are some more detailed item descriptions.
Independent Electronic Boost Controller
Ref: High Performance Electronic Projects for Cars - Silicon Chip Publications.
Absolutely superb control over your turbo boost curve. It can be used in cars fitted with factory electronic boost control using the factory control solenoid, or cars without electronic boost control using a solenoid from a wrecker etc. It actually has two different completely programmable boost curves. This is ideal for switching between say, a race / street mode, or a performance / wet weather mode. Each boost map has 64 points able to be adjusted in 1% duty cycle increments. Boost curve selection is via a dashboard switch, and it is all programmed using the Handheld Digital Controller - KC-5386. Kit supplied with PCB, machined case, and all electronic components.
* Suitable for EFI and engine management systems only.
Hand Controller for Digital Adjusters
This hand controller is used for the mapping/programming of both Digital Adjuster kits. It features a two line LCD, and easy to use pushbuttons. It can be used to program the adjusters then removed, or left permanently connected to display the adjuster’s operation. It is designed as an interface and display, and is not required for general adjuster functions after they have been programmed. If you have built and installed multiple adjuster kits, you will only need one controller to program, unless you want permanent displays for each adjuster function. Kit supplied with silk screened and machined case, PCB, LCD, and all electronic components.
Requires RS232 Connecting Computer Lead (Use our WC-7502 lead)
Intercooler Water Spray Controller 03/06
Ref: Silicon Chip March 2006
Intercooler water sprays are a very effective and inexpensive way of upgrading intercooler performance. Using a 'dump' system to trigger the spray often results in the need for frequent water top-ups. Simply add these few components to the Smart Fuel Mixture Display Kit (KC-5374) and reduce water consumption by up to two-thirds with no loss in cooling efficiency.
Digital Fuel Adjuster
Ref: High Performance Electronic Project for Cars – Silicon Chip Publications.
This unit is a huge revolution in DIY automotive performance. It gives you the power to completely tune the air/fuel ratio throughout the entire load range, at 128 load points, providing incredible mapping resolution and brilliant drivability. It uses the Handheld Digital Controller – KC5386, so there is no need for a laptop, and it supports both static and real-time mapping. It can be used on 0-5V and 0-12V signals, so it is compatible with all voltage output airflow meters and MAP sensors. It can also be set to work with 0-1V signals, allowing modification of EGO sensor signals. This unit has been extensively tested on a wide range of cars including Subaru Impreza WRX and STi, Nissan 200SX, BMW 735i, Lexus LS400, and Nissan Maxima. Kit supplied with PCB, machined case, and all electronic components. Kit requires the Handheld Digital Controller – KC5386.
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
