G'day!
Just wondering if I could get some assistance for my next planned upgrade on my car...
So far I've got 3" turbo-back and a Greddy intercooler, I've also got a NISMO fuel pump that is yet to be fitted, and I'm going to be buying a VIPEC sometime in Janurary.. However, since my intercooler upgrade, by stock intake system has been somewhat 'truncated' and now isn't flowing that efficiently. I'm leaning towards a boxed pod, however, due to the fact I half live in the country, I've been told that dust and pods aren't really the best of mates. If I do go that way, I've read that K&N are the best filtering, and 3rd best for flow of many pod filters tested in Aus.. However, i've also been reading that ARC make some pretty nifty producted, and I'm particularly interested in the super-induction box.. Now is it a box for a pod or is it a replacement for the stock air-box??? Do they work well or not??
Also, what are the flow/filteration rates like on the SIA?? Also, are they legal here in WA??
Please, I'm asking anyone that has a super-induction box in their car to throw up some pix.. Also, any adivse on the pod setup is very welcome! :cheers:
Just need some pointers!
Thanks!
Mark.
https://www.sau.com.au/forums/topic/243777-arc-super-inductionpod-setup/
I've got an ARC box but haven't fitted it up.. brackets don't make sense and I need to devise a way to get cool air to the TOP of the box :P
Looks like a nice bit of kit, basically it's a replacement airbox with a panel filter on top. Really needs a small scoop directly above it and some foam to seal to bonnet me thinks.
As Phemline said... I don't see why an induction box would be illegal if it is tightly secured.
flow and filtration should be good, I'd be more concerned about the temperature of the air going into it.
Technically all pods are supposed to be boxed and secured anyway. You shouldnt have an issue with legality.
pods do NOT have to be boxed only secured
Marco just get a K&N panel filter to go straight into your stock airbox
Edited by gazza750
Well that is what I wanted to do in the first place.. However after I got my intercooler installed I noticed that the induction part to my airbox had to be taken off in order to fit the intercooler piping... Hence my airbox is sucking in hot air from the engine bay, as opposed to drawing in cool air from the front.. Hence the airbox has lost the greater part of its efficiency and it makes more sense looking for an alternative setup..
Hey Dukes, I heard you make a CAI for your pod setup... Any chance you could throw up a few pics??
Yep,
I had the same problem the stock snorkel wouldn't fit, so got a pod, but it looked like cop bait.
So i made a template out of cardboard, then marked and cut some sheet metal, then spray painted it, I used wrinkle paint to get a stock look, and got clarkrubber pinch weld for the edges.
I got some 1.6mm ally sheet and used the jigsaw to cut 2 strips out then bolted them from the afm/pod bolts back to the chassis, worked a treat and passed the pits fine.
I also had one of my cooler pipes cable tied back to the waterpipe that comes off the manifold, in an effort to keep the pipe off the fan when the bonnet closed.. also passed the pits fine :P
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
