mate im preeeety sure i got one sitting down at the mother-in-laws place, may be a tacho tho, will have to wait till the weekend till i can have a look but if its a boost guage ill hook it down ur way, at ur expense from the gold coast, if u dont get one before then ill let u no.
https://www.sau.com.au/forums/topic/244432-wtb-boost-gauge/#findComment-4256258
