Lines In Cairns
Originally posted by Spooks_Skyline
man, plenty of good ranges to hit in cairns'
up gillies, across the tablelands, down kuranda or the other way
up to port douglas and the rex range out that way is a kik ass drive as well
true that, i driven all through tablelands, daintree national park and port douglas!! Pity it was just in a hire car tho
what do mean, a pity!
hire cars are awesome
they can do things that normal cars cant!
I originally hail from Kuranda, at the top of the range above Cairns. I got my 'line about 3 months before I moved to the sunny coast about 2 years ago and they were rare as then. There were less than 10 in Cairns. I had such a ball driving the Kuranda range everyday for work. My dad bought a 2-door STi for the same reason. I used to go sub 5-minute top-bottom or bottom-top. Going up was always the most fun. Overtaking drift style in 3rd gear sticks in my mind! I am going back next winter for an extended holiday so I am trying to get my cat up there as well to have another crack at those twisties
hehe, that sounds alike a blast (going up and down the kuranda range)
i must have done that trip about a gazillion times in my old girls corolla (it took us about half an hour :P )
would love to take my skyilne up there and have another crack at it!
Yeah, more fun than the gillies. Has less corners and is faster. Port road is sweet as is the rex range too. Going up in the old man's STi was ballistic! That thing is like a go-kart. He regularly eats road bikes up. An R34 GTR is next for him I wonder if that will be quicker again
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
