For sale is my 1983 ADM AE86
Bought this car 1 year ago, had great fun with it, always been well looked after and serviced every 5000kms, engine starts every first time.
Only used as a daily, had suspension setup as a drift car, but never drifted or been on the track. It's a bit bumpy for a daily, but handles like a go-kart!
Come with factory handbook and service history. And FULL ENGINEERS REPORT (paper provided) covering all modifications. Ensures no registration problems. VicRoads approved. Wheels / Power increase / Engine / Unleaded conversion ect, all covered in Engineer Report. Even small engineer required items such as Unleaded fuel sticker on inside of fuel filler door has been taken care of.
Price: $8500 will consider serious offers
Here is a list of the mods:
ENGINE:
4A-GE Big-Port, 150,000kms original
Professionaly modified intake manifold by engineers
BMC Air filter
4-2-1 TRD copy headers
Custom cat back exhaust system (great tone)
EFI Factory ECU
Oil cooler
Engine Oil Catch Can
Bosch Fuel pump with new fuel line
SUSPENSION: (All installed)
Coilover strut (On a legal height currently, but can still go another 2" lower)
CUSCO camber top
T3 RCA
TRD TOKICO yellow front shock
TRD blue 8-way adjustable rear short stroke shock
TRD springs 8kg/mm front, 6kg/mm rear
Nolothain suspension bushes all round
DRIVELINE:
Front JDM brake caliper and vent-disc
T50 Gearbox: tight and good
New shifter bushes
Exedy Sports Heavy Duty clutch
New wheel bearings
INTERIOR:
MOMO steering wheel with centre MOMO padded cover to avoid roadworthy defect
AUTOMETER Oil pressure guage
Alloy gearknob
Pioneer CD/MP3 player
4in Jaycar fidelity front speakers
Amplifyer wiring kit.
EXTERIOR:
Firbe glass front lip
HID kit 6000k
Japanese WORK 15x6.5" rims, Super light weight. 2in dish. (One pair painted gold center.)
CONDITION:
Straight chassic, no repair
Shiny original factory White paint in immaculate condition
3 doors are rust free. minor rust on normal place.
Slight dents at the rear, see photo 2
REGO till Jan 2009
RWC: N/A
But easily obtained. All you need to do is reinstall the standard suspension, which you can have them for free.
Free standard parts:
Original front struts, strut tops and set of 4 springs.
Full length front and rear shocks.
Set of original wheels with road worthy tyres.
Reason for sale is upgrade to a newer car, time to move on~
Contact: 0401 666 024 SHAUN
No time wasters, tire kickers or joy riders, thanks
https://www.sau.com.au/forums/topic/244937-fs-ae86-mel/
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
