Ok, I've got a HKS series III avc fitted and it works fine etc.
I took the car to a dyno and got all the figures etc
My car was peaking out at 15.7 psi boost according to the figures.
So if I tweak my avc up to say 2.5 bar [35psi approx.], does that mean it won't make any difference cos I top out at 15.7 [1.1 bar].
I don't understand, currently my low/high settings are 0.75/1.2 kg2/cm [which is close enough to 0.75/1.2bar]. But I could reset the HKS to anything really, from mild to wild.
Somebody know the answer????
Danny.
https://www.sau.com.au/forums/topic/24502-hks-avc/
Thats a negative, 15.7psi at 105kph on the dyno. Dropped to 13.9 at 170kph. But still doesn't answer my original question.
Thanks for the reply though BOOSTD.
Maybe someone out there knows the answer.
https://www.sau.com.au/forums/topic/24502-hks-avc/#findComment-528964
The turbo WILL boost more if you adjust the boost controller! When you refer to "low and high" settings, it is either one or the other. So if you have it set on high.....15.7 is pretty close to 1.2bar. The EVC should be reset every time you perform a mod. I have found my HKS EVC4 needed to re-learn after every mod or the boost levels changed.
https://www.sau.com.au/forums/topic/24502-hks-avc/#findComment-528978
I don't get it, does this mean that my turbo will boost past 15.7psi, I thought 15.7psi was the limit. I can vary the boost, it has a knob I can turn on the HKS avc. But I've decided on the two settings for the High and Low switch. I can change this with the knob and /or reset the internal settings using the Mod switch any time [but probably won't].
But a turbo must have a finite boost limit, and then you buy a bigger/better one to go higher etc [realise that this is also dependant on injector, pump, exhaust sizes etc too].
They just revved it out on the dyno and gave me the sheet and graph, but I am assuming that they would have found the boost limits and applied them. They just said this is the boost and we've set yours to 0.7/1.2 and that will be safe for this car and setup. Surely they didn't arrive at this figure by chance.
I think I'm getting more confused as I go.........
https://www.sau.com.au/forums/topic/24502-hks-avc/#findComment-528993
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
    • lol the 2nd one boss, thank you for pointing this out. I feel as i spend more time here this intro message is some thing i will always make me laugh and shake my head at. Perfect Intro:  I have the vehicle
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
