hey guys.. just a quick question
im getting my car dyno tuned and a vipec installed on friday, and getting the boost control set to 10 and 16psi.
car is a
96 s2 rb25det
kkr 430 turbo
fmic
just wondering if im gonna run out of fuel when shes all tuned up and running schmick, a mate has said i might with the power il be running
thanks!
https://www.sau.com.au/forums/topic/245203-will-i-need-injectors-fuel-pump/
car is a
96 s2 rb25det
kkr 430 turbo
fmic
thanks!
don’t expect much power from the kk430, i'd look out for boost issues if your running a internal wastegate?
you will need a new fuel pump eg: 040 or walbro, injectors will run very close to max and your AFM will max out if your going to run 16psi
i suggest:
bosh 040 or walbro
bigger injectors
z32 AFM
keep us updated, keen to see the end result
here is a recent build that i just finished for a friend of mine, might give you some good info.
http://www.skylinesaustralia.com/forums/Mo...st-t239039.html
cheers!
yeh mate internal wastegate at the moment, iv been well informed about the boost issues. read your thread too.
at the moment going off my boost guage it doesnt go past 12psi, reckon that will be a problem? mate said he has seen them creep to 18psi :S
also with the ecu im getting (vipec) it doesn't use an AFM, its map sensored or whatever its called (don't really know much at all about this - anyone who is bored feel free to explain it to me, i need to do alot of reading over the next few days !).
So you think il need a new fuel pump definitely, il see how it goes on the dyno and post results etc over the weekend!\
oh by the way all the work is being done at godzilla motorsport
i'd be very surprised if you don’t get boost creep, they all do it and just unavoidable.
with the supporting mods, your fuel pump may or may not be enough you just don’t know in what condition it's in. this also comes down to reliability, why would you want to risk your car leaning out and causing serious damage to your engine which will result in a rebuild.
same goes for your injectors, you will be running them on max and it’s just not safe and will limit the amount of boost you can run.
if your going with the MAP sensor option there is no need for a AFM so no need to worry about that then.
i suggest you go with a bigger pump and injectors to ensure you have enough fuel to keep it safe and to achieve the desired result.
:ph34r:
i'm in the same boat but i have a power fc and kkr480, i was looking at injector and pump for it.
Can you change it to be externally wastegated??
pretty sure you can weld it up so that it requires an external, dont ask me how though lol.
just been looking at turbos to buy and saw a couple that had been made into external.
Ps good luck with the build up existence, definatley replace the pump atleast (old and worn out) mine is about to crap itself and im only running bit above stock power.
be best to keep an eye on the fueling side as well so get yourself a decent fuel pump and injectors.
my 34 has the mods listed below in my sig my im maxing out my stock injectros and it pings at high boost so upgrading them next week to 480cc. better to be safe then sorry mate.
save up a little more dosh and get it done properly. get yourself a highflow fuel pump and decent injectors. fuel pumps are not that pricey its the injectors that are the killer, but its better to have everything and take it and et it all tuned at once as you will be saving on getting the injectors tuned again.
if your interested in injectros check out power flow injections here in melbourne. they quoted me $840 for 480cc injectors for my 34 http://www.powerflowinjection.com/ and so far they have been the cheapest.
so ye get you pump and injectors first before you try and tune it for high boost or you will end up spending more money on a rebuild.
or if you really really really wanna get it put on asap put it all in but tune it to a safe boost so around 200rwkw till you can afford to upgrade the injectors and pump
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
