Mr Bozman would it be allright if i come out and take some happy snaps???
Just for reference im the guy whos normally out at the circuit club days takeing photos :P
cheers
matt mead
www.matthewmead.net
Edited by matt mead
  • Replies 61
Hey Mattman
Of course you can come to take some pics. HAHA and yes I know who you are :)
Did you want to come Neil? The Radical is welcome as it is really not an open wheeler ( no exposed wheels )
I instruct at the Radical days, so if you would like to come out and play you are most welcome to. Has it got a passenger seat so I can come for a ride ??
After todays effort my old "slow" GTR should be able to make it.
We didnt break anything to major, just needs some AWD back and a few new master cylinders.
Shame you missed today at wakefield John.
Was kinda an interesting day.
Got your PM's, but for some reason I have never been able to reply tp them :)
Still spots left. Ring the office monday-friday 9.00am-5.00pm (02) 9829 5399
Cost is per person, not per car.
Hope to see you next weekend :)
Hey Mattman
Of course you can come to take some pics. HAHA and yes I know who you are ;)
lol the last person to call me Mattman was luffy the first time i introduced myself ahah funny conversation
Im locked in so ill be out there all day :)
I would have loved to John but I need the car corner weighted and aligned which didn't happen last Saturday unfortunately.
Sorry no passenger seat in a Prosport mate. My steering wheel is pushed more to the left than an SR3.
Have a merry christmas John and don't work to hard.
Neil.
any good places to hire a trailer? ryde area or penrith area?
Buddy,,,hiring a trailer is a hit and miss affair,,,most of them are crap. No brakes,,no tie down points ect.
Good luck is all I can offer you,,,then again it's only at Oran Park so if you it take slow you should be alright.
Neil.
Oh Matt you where there :) I couldnt see you anywhere! wanted to say Hi :down:
Was funny seeing Luffy get into Frickers new Radical :) And that little BSM car was hilarious :laughing-smiley-014:
yeah that starlet looks tough!!!
what times was it doing?
The starlet was funny as!!! Not sure the times it was doing the thing was breaking traction all over the place :( Lofty was having a ball!
Yeah that starlet was damn quick, as you would expect from basically a full on race car setup...
It was a good day, my first track event ever and I was getting 55.8 (handtimed) on end of their life nangkangs, they were mushy by the end of each run... Damn I flogged them...
A great day had by all. Thankyou to those who turned up :banana: Lofty in the starlet was doing 47's. Not bad for a car that is only 1800cc, has a restictor on the turbo and had yokohama controlled semi's on all fours that were 3 years old. It was the cars very first run, so will be faster by the time it rolls out for its first race meeting in late January.
For those of you that don't know it is built to Improved Production Car regs ( IPRA )
Mattman, your photo's are awesome as usual :)
John, when the starlet is all sorted, xwhat times u think it can do? Cause that's flying already!!! And what motor is in it? So lofty not racing the 32 in 09?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
