Hi All,
Was going to paddock this, but the property is not available till Feb and I don't want this sitting around till then.
It's a 1989 EA s pac sedan.
-Only 200,000kms
-Silver in colour.
-MPI 3.9
-4 speed auto in VGC (with factory trans cooler)
-Fully working, cold air conditioning!
-Interior in VGC.
-2.5" mandrel bent exhaust. 1 muffler, flanged at the cat and the diff, so very easy to remove and bolt in to another car. Not overly loud, but sounds very good.
-Engine drives very well, no real smoke or noises.
-Steering and suspension feel nice and tight.
-Body is in GC, however there are fairly big scrapes to the driver's front guard and driver's door. I can supply excellent replacement panels in another colour.
-Factory Snowflakes in good condition, with approximately 70% tyres all round.
-New windscreen.
-New battery.
Car is located in Cheltenham VIC.
After $450 for it. No reg or RWC. Please note that pictured towbar will most likely be removed prior to sale.
Please post or PM for any questions.
Thanks,
Justin.
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
