Hey guys, Ive got some boost issues i cant figure out, its driving me NUTSS..Well, im not making more than 0.1 bars of boost (havn't tried boosting it yet). The car drives o..k with almost no lag until the time boost is meant to kick in, you dont feel the lag once your in boost mode, but both my A/M Apexi boost gauge and stock gauge show me that im running under boost, also the car doesnt have that 0.5 bar pull it once had. i have tried the following with no positive outcomes:
- Change all vacuum lines
- Change wastegate to R32 wastegate (as soon as i changed this, i had a boost up to 0.7 bars but with heaps of lag and backfires, so pretty much no difference)
- Change Intercooler Pipes (not core, although core has some dents in the fins which i doubt would cause a leak or anything)
- Replace Cat with De-cat Pipe (incase i had a blocked cat)
and....nothing else so faar.
i should also mention, i have takin my car for a dyno tune and the guys there tottaly gave up on my car (but back then the car was having some other issue which has been takin care of)..by the way, when it was worse then it is now, i pulled out exactly 143.2 hp...isn't that sexiful hey..lol
Neways guys, PLEASE HELP ME OUT, im wanting to mod my car but dont want to mod it and increase possibilities of a dead engine..
Edited by A-B_DR/fT-KinG!!
https://www.sau.com.au/forums/topic/247039-r33-boost-issues/
hey guys, found out that my boost gauge vacuum hose was almost off!!!. fixed that up and im now getting 4.5 psi below 4500rpm and 6 above...
its gone better although i thought it was meant to be getting 10psi with the r32 actuator??..am i not right??..
Disconnect the vacuum lines on the boost solenoid (located behind your airbox/pod) and join the two ends thus bypassing the solenoid. This way, the amount of boost you run will be dependent on the actuator; in this case, 10psi.
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
