hey guys got a few things for sale from a few gtr's ive had
nismo plenum complete with throttle bodies etc $1800
greddy plenum with single 100mm throttle body $1100
cusco 6 point roll cage with carbon fibre removable side intrusion bars $1500
19x10.5 +12 volk te37 wheels in bronze with bridgestone tyres approx 80% - $5000. not negotiable. not a dollar less.
immaculate condition bar 1 wheel whcih has a slight 15-20mm surface scratch, no gutter rash on any.
SMS 0410 487 487 FOR ANY FURTHER QUESTIONS
WILL POST PICS WEDNESDAY
THANKS
ALL PARTS LOCATED IN LIVERPOOL, SYDNEY
Edited by SRB
heres some pics, sorry they were taken from my fone!! carbon intrusion bars, and full 6pt cusco cage with everything needed to install!!
greddy plenum pics on monday, been realy busy and they at my brothers house
i gotta find the throttle bodies for the plenum, but i have the puley spring accelerator thing, if i cant find them, will sell for 1600
Edited by SRB
hi it wont fit, only r34
pretty sure its steel, no1 makes moly bolt ins i dont think
side intrusion bars are cusco items yes, pure carbon fibre! they retail at 2k alone!
thanks
19s sold.
are there any small parts that come with the nismo plenum other than the tb springy thing?? eg metal piping and hoses etc?
no, u just use the existing standard stuff, and since taking it off i have no idea where ive put them.
needs to go after xmas!!!!!! cage and 2 plenums still 4 sale.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
