1998 Nissan Stagea
Series 2 Dayz Edition
Reason For Sale: Chasing something different again, also buying a house soon so want something a little cheaper.
General Info:
4spd Titronic Auto (Rebuild about 15,000km ago)
Dual Sunroofs
Genuine Stagea Floor Mats
Cargo Blind + Barrier Included (Quite rare to find)
Car is in overall good condition although cd player doesnt work.
Serviced Regularly
Odo Reading ~120,000km
Mods:
Splitfire Coilpacks
Turbosmart Manual Boost Controller (Running 10psi)
Venom Boost gauge (smoked face)
Carmate Remote Start / Turbo Timer
Lowered On KYB SR Specials
Dolphin Grille
Pics:
Price and price conditions: looking for around $19,500 but open to offers, trades with cash adjustment my way welcome.
Contact Details: PM me on here or call me (Corey) on 0400069925
Delivery & Conditions of Delivery: Sorted With Payment
https://www.sau.com.au/forums/topic/248340-fs-1998-nissan-stagea/
