Not 100% sure if it is genuine i bought it off another guy and then never put it on.
Dimensions are 1250mm long x 75mm wide and 60mm high
Located in Park Orchards (Eastern Suburbs)
Edited by ALL GTR
might be a bit irrelevant, and sorry if it is
BUT, whats the difference between a genuine on and a copy,
it's really hard to tell with t uder the wing, and for the sake of a visual enhancement, does it really matter.
unless the fitment is different???
I have one on mine and never really asked myself if it is a genuine one or copy, so just curios relly,
sorry, gotta stop writing silly threads when i have had a bit to drink.
the genuine lips are plastic and have two indents where it goes around the stock spoiler
anything else is just a copy all the carbon fibre and fibreglass ones you see
Ahh yes that's true the genuine ones have the cut outs for the original spoiler. In that case its just a copy. (Plastic)
If you stick it to your boot properly it wont warp.
Edited by ALL GTR
