Be careful on repaired vehicles offered for sale out of Japan.
Be carefull as some people are offering repaired modern cars for sale out of Japan as they are cheap but may end up costing you your car.
The rule is below so read into it dont take somebodys word for it.
A RAW would take all reasonable steps to avoid importing a crash damaged or corroded vehicle.
A RAW wont put up his bussiness to save you money.
In a nut shell they are saying dont bring in a damaged or repaired vehicle. I know of one complyier who knocked back a car as they were told by the importer it is a repaired vehicle but only minor damage. They knocked back the work and said unless you are 100% sure it is minor it will be at your cost. So the buyier went back to the broker who wouldnt sign a document that the car will pass the RAWS inspection then the importer went a bougt a straight as car to save the trouble.
Damaged Vehicles
Crash damage or corrosion may affect continued compliance with the ADRs. This is especially so in the case of the occupant protection ADRs 69, 72 and 73. It is not possible for a RAW to provide a reasonable level of assurance that a crash damaged or corroded vehicle, where the structural integrity of the vehicle has been affected, complies with all of the applicable ADRs. Therefore, it is not permissible for a RAW to fit a used import plate to such a vehicle.
Before commencing compliance work each vehicle must be inspected by the RAW to check for crash damage, damage repair or corrosion that may affect the structural integrity of the vehicle. Records of this inspection are to be retained by the RAW and be made available to VSS inspectors upon request. (Regulation 57)
Crash damaged or corroded vehicles where the structural integrity may be affected must be re-exported or destroyed. It is expected that a RAW would take all reasonable steps to avoid importing a crash damaged or corroded vehicle.
The criteria below must be used as a minimum when deciding if crash damage or corrosion is likely to affect the structural integrity of the vehicle.
q Underbody damage which results in the:
Ø crushing of floorpan stiffening members,
Ø splitting of seam welds or
Ø tearing of the metal
q Damage to rocker panels (or outer sill) which result in:
Ø Dents to a depth of more than 25 mm
Ø Creasing, distortion of the sill weld
q Distortion to longitudinal rails affecting the front and rear crush zones.
q Collision damage to steering or suspension components.
q Damage to the vehicle’s outer body panels, which affect the integrity of any of the seams or joints installed by the vehicle manufacturer.
q Corrosion (rust) which has resulted in perforation or flaking of the metal.
When checking the condition of the vehicle the following items need to be inspected but not necessarily in this order:
q Engine compartment
q Right side
q Luggage cargo compartment
q Left side
q Underbody or chassis frame
q Passenger compartment
I will always drive a import, Soarer loved it, 180 now that car is fun and RX7 sitting in showroom waiting for me to sell 180.
It is worth it and take advice from people that have nothing to do with the people you are buying off and dont rush.
I have personaly seen a couple of importers telling the truth to buyiers knowing that they wont sell a car to them, they just want to tell the truth, they have a heart beat.
    • A quick google, and some E39 users have found pulling my sensor out/apart and cleaning it alleviates their issue. Then get the oil warning to go off, and once it is off (from the sensor saying it was unhappy) some find they can just unplug it and it is happy to just keep going now. Maybe give it a crack? If you can actually pull the sensor apart, hit it with some electrical contact cleaner.
    • Yep. In the E39 it's slightly different than the others. Honestly I'd just leave it but every time I drive the car it tells me oil is low and that just makes me check the dipstick. It is a BMW Afterall and it tries to expel it's own oil regularly.  Thankfully it's not like my E90 that has no dipstick at all so you just gotta trust it.
    • Was that also a typo? $350?! Just typing "BMW oil level sensor" and prices start out a lot more sanely than $350. I'm guessing it's a sensor used in one low volume model only or something?
    • They kept the product number the same, so we "didn't pick it up when packing your order". If you packed the order, you clearly saw the box wasn't Hella...
    • Actually, the equivalent skyline part is both cheaper and simpler, maybe you should come back from the dark side?
