No, this isn't a thread about breaking the drought and getting some action.
Its about how I went for a cruise last night and didn't see one cop until........ "duh duh duh"
I was approaching the cnr of Commercial Rd and Chapel St. I'd just realised that I'd seen no cops at all when one pulled out of Izett st directly behind me.
We stopped side by side at Chapel St and he moved forward to checkout my front bar.
Now, my ride is prolly shy of legal height by about 5mm and with the 400R kit it looks even lower. I acted as cool as I could and pretended to be oblivious to the cop looking.
When the lights turned green we both moved off with me trying not to run boost at all so he wouldn't hear my BOV. Needless to say I moved so slowly I had tolook suspicious.
However he couldn't have given a toss and turned into Chapel.
I stopped sweating and booted it all the way to 60km/h haha to get the phuc outta there.
I must have built up a reserve of good karma with all my legal driving so the cops leave me alone.
It was a good night.
https://www.sau.com.au/forums/topic/25071-oh-the-relief/
  • Replies 49
Popular Days
Originally posted by 32_ENVY
My god you start a hell of a lot of threads man, keep up the good work
I know dude, but I thought someone had to liven this place up a bit.
The therapy thread and the genital piercing one were just the tip of the iceberg. Stay tuned for "Wardest's Wasteland", Wardest's Warzone" and "Wardest Wants Action".
They are gonna be all class threads and a total tear up.
To quote Beteljuice,
"Let turn up the juice and see what shakes loose"
https://www.sau.com.au/forums/topic/25071-oh-the-relief/#findComment-532343
oh and wardest, lucky ay, everytime a cop has ever followed me they have pulled me over
he saw you were not a p-plater and left you alone  they do that
:) cops have fully looked in my car, see all sorts of flashy doovas, shrugged and move on.. they don't care about older ppl driving skylines coz when you turn 25 you never drive fast or anything :D
p.s. shutdup amateur whores !
https://www.sau.com.au/forums/topic/25071-oh-the-relief/#findComment-532379
Originally posted by pushead
How about whorer of the month goes to.....
WARDEST! :D:):D
I'm no whore, I just start the threads that get the whole club whoring.
C'mon, tell me you don't like it and I'll stop.
Where would any of you be without my "in your face thread" stylz?
I'll tell you where, back in the Wasteland, posting drivel and getting bored.
https://www.sau.com.au/forums/topic/25071-oh-the-relief/#findComment-532393
but where posting drivel here. BTW, i like cheese
But its not drivel when the thread is started by me. :D
Its carefully structured, entertaining, stimulating banter.
Why do you think you're all having such a good time? Its coz I'm pulling the strings.
https://www.sau.com.au/forums/topic/25071-oh-the-relief/#findComment-532411
Ward, the ride height is measured from the lowest point of the car to the road so it doens't matter that the bottom of your car is 5mm short of 100mm, they will measure it from the lowest point which would be your front bar and I know you can't fit a Coke can under that...
https://www.sau.com.au/forums/topic/25071-oh-the-relief/#findComment-532418
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
