Hi people,
im thinking of buying a series 2 skyline, with hi-flow turbo, intercooler, exhust, bov.
i was wondering if i need an engineers certificate for any of these mods for insurance purposes and if so how do i obtain them?
i also wanted to know if anyone knew any good performance workshops so i could get the car inspected as the nrma wouldnt know too much about mods like these.
thanx for your help guys :(
https://www.sau.com.au/forums/topic/25232-engineers-certificates/
the short answer is no for insurance reasons.
but if you are looking for an engineer, taken from this thread...
"By far the best engineer I've had the pleasure to deal with is a guy by the name of Phil Scott who deals out of Grafton. He visits Sydney on a regular basis and is most helpful (a trait which I found is most lacking among engineers). His number is (02) 6647 7558"
in situations like these you shouldn't take the word of some stranger on a forum so i'd advise you to check with your insurance company to be on the safe side. situations and circumstances can wreak havoc if you know what i mean.
having said that, i don't know of anyone that has had to produce an engineers certificate to get insuance. that's only half of the story though. once you have insurance you want to make sure they will honour it and this is where it gets scetchy and why i don't like to listen to anyone except the insurance company in question. you see, in the case of an accident where the car is written off and they have to pay you out the insurance company will look after their best interests (their money) and try to screw you by proving that your car was not roadworthy due to modifications which were not engineered.
best advice i can give you is call your insurance company (if you don't have one call as many as you can) and ask them if they will pay out in the event of a write off and where you haven't got an engineers cert for certain mods. and be specific be specific be specific. the only person you are cheating when it comes to disclosure is yourself.
goodluck
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
