Hi all,
Got a set of four RS-GT 19"x8" wheels. These came on my '93 slicktop 300ZX and I don't have any need for them as I have lightweight Ray's already (and 8" wheels are a bit skinny for a 500 hp RWD V8 ;))...
Tyres are Achillies 235/35's all round. The guy I bought the car off bought these new before the timing belt went less than a 1000k's later and he sold it to me.
Unsure of wheel offset, but fit perfectly on the Z, so assume that they will suit a R33. Nothing is stamped on the inside other than the load rating and width. I'd suggest you come round and try them on if you are interested.
Chasing $1500 ONO, I want them gone. Cluttering up my shed :action-smiley-069:
Located on the Northside of Brissy, pickup/drop off only.
You can PM me here, or on www.aus300zx.com, or e-mail chrispy300 at hotmail etc or 0400 023 604.
https://www.sau.com.au/forums/topic/252762-19-x-8-rs-gts-nearly-new/
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
