Hi,
This is for Darwin NT people however I am impartial to interstate inquiries.
Details are as follows:
1996 Galant VR4, Metallic Purple (Trigger Mauve)
2.5L V6 Twin Turbo 4WD
Active Yaw Control
86,000km
Climate control, Power everything
Mods:
K&N Rampod air filter
2.5" Al hard piping kit
600x300x76 FMIC
Turbosmart Type 1 BOV
Twin 2.5" SS dump pipes to 3" Hiflow exhaust system
Haltech Interceptor ECU tuning: boost, ignition timing & fuel
Evo 8 Enkei rims
Pillar mounted pod B&M high vis boost gauge
Top gun leads, Iridium plugs
Performance:
Power - 218awkw (estimated)
Boost - 14psi
0-100 4.9sec
0-400 - 13.3@101m/h
Overall this is a very well looked after vehicle with servicing done regularly, oil changes vigilantly done every 4000km, Auto trans done every 10,000km. Extremely easy to drive and handles beautifully.
Asking: $20,500 neg (which means make me an offer!)
Ph: 0415 458 465
[email protected]
Thanks
Josh
A little vid I made of Hidden Valley Drags:
http://au.youtube.com/watch?v=tocjo1sGMsg
https://www.sau.com.au/forums/topic/252826-96-vr4-galant-1331013-darwin-nt/
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
