plug ok? check and clean.
other wise get a multi meter and check for a curcuit on the wires that come to coil 6. if open curcuit then you have cut or problem in the wires
Yer the plug is ok not dirty or anything & i swappd it when i swapped the coil pack 2 make sure..yer il chek the wireing thanks..coud it b the injector? Prob not cos it come up with ignition system fault code but u never kno sometimes
https://www.sau.com.au/forums/topic/254665-runnen-on-5/#findComment-4396526
if you had a noid light handy you could check the pulse.
feel if its ticking. unplug when running and listen for a change
Yer i hav checkd & have power going tru the coil on that cylinder same as all the others..i dont hav a noid light 2 check injector pulse n i cant really tell if its ticking jus by touching it & if i unplug it will jus b the same as unplugging the coil..missfire...coud it b something bad like burnt valve or something?..-but i dont think a injector problem or burnt valve wood log an ignition system code..or wood it?
https://www.sau.com.au/forums/topic/254665-runnen-on-5/#findComment-4399433
Ar its ok dont panic the computer jus wasnt plugged in properly!dont kno why that make just no6 go bad ok thankr
https://www.sau.com.au/forums/topic/254665-runnen-on-5/#findComment-4399513
