Item: 180sx
Website: here
Item Condition: fair
Reason for Selling:kid on the way
Price and Payment Conditions: 18grand or swap for tuff 4door. swap is what i would rather do
Extra Info: front bar and guards need replacing/ repairing
Pictures:
Contact Details: pm me or post here. or email me or add me at [email protected]
wheels /suspension
advan racing 17x9 and 17x8 tri spoke wheels
255's rear 235s front getting close to be replaced
5mm front spacer 25mm rear bolt on spacer
billet 5 stud hubs front and rear from just jap
r32 rotors /calippers front std rear
hot bits coilovers
jic caster rods
aluminium cradle lockers
body/paint
ford envy green with extra gold pearls
including engine bay and rocker cover
30mm wide rear 25 mm wider fronts
full uras bodykit and clear lights to suit
gearbox/ clutch
os giken twin plate clutch.
os giken 1st 2nd 3rd hardened gearset
engine/ turbo
greddy sump
eagle rods
aries pistons
fully balanced bottom end including clutch
arp head/main stud kit
arc race bearing
reseated valves
new exhaust valve guides
all new seals through engine
jun high rev valve springs
jun 264 11.5mm lift in/ex cams
tomei rocker stopper kit
increased presure oil pump
walbro fuel pump
malpasi fuel presure reg
tomei 555 injectors
stainless low mount manifold
garett gt2530 4inch infeed rated at 440hp
gktech exhaust
4 inch intake pipe into standard position for airfilter
hks airfilter
hybrid intercooler kit modified hotside
gfb blow off valve "bovus maximus"
earls oil cooler and filter relocater kit(not on car)
twin electric thermo fans
interior/electrics
apexi avcr boost controller mounted to climate controls hole, controls removed
apexi power fc d jetro series
apexi pen turbo timer
splitfire boost guage
autometer oil pressure and water temp guages mounted in centre airvent in custom mount
kenwood head unit kenwood 6 inch speakers in front
power cable and rca's running to boot
sports steering wheel
bride drivers seat
Edited by yogi_in_a_180
https://www.sau.com.au/forums/topic/254881-180sx-sr20det-sell-or-swap/
whats wrong with the front guards and bar??
guards are both split and bar is chipped
also all tyres recently replaced
new coil packs, the red ones lol
gk tech stainless exhaust
What ECU,
do you have power figures?
how much boost, when was the engine built and who by....
can u put up photos of the damage?
Edited by axe s
What ECU,
power fc d jetro the one with a map sensor
12psi atm
engine built bout 15,000 klms ago by myself
never had a full power tune only but was dyno tuned to run without leaning out made bout 260hp
will try get pics of it soon gotta charge digi cam batts
pics of anything else?
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
