hey guys back for sale is my 1995 toyota supra single turbo i have 9 tyre kickers and im sick off them so please pm if really interested no more time wasters!
ok its midnight purple 18inch chrome mags new treads all round fully recoade head all full gasket set to replace (not running) heaps of money spent can get it repaired for you by mech for 1k + dynoed tuned it has custom du-luck front bar veilside side skirts full 3 inch exhaust turbo back hybrid front mount cooler its an auto 1995 rz so you must look at it first before buying pics dont do it justice cause there old and i need camera please call me for info on 0400770161 cheers matt. PRice only 10k but will swap for manual gtst skyline plus cash my way pm with pics of your car this price is dirt cheap cause i need it gone cause i have my wedding comming up on the nov 14 this year need cash but im after a skyline selling the supra as is no reg or plates
Whats required to get car running again? just head gasket replacement n re-assemble? What turbo is it running? ecu?
i have the gasket for the head all it needs is a set of head bolts rrp $60 it is a to4 front and t3 rear for quick spool up its very fast i can get my mech to put it back together for 1 k so its dyno tuned so its running nice not rich or lean to get maxxium power it will run low to hi 12's easy i have 100 percent confidence in it must see cheers mate
and it has standed ecu
Edited by TwinTurboSupra+R32 Gtst
i know u said ur after a manual but would u look at auto r32 gtst for swap and cash ur way if so let me know and ill email u some pics and details through of mine
hey guys my car is now fixed cost me 1k and now its running a dream all sweet price is now $$12500 its as is can sell with reg but no time to get roady working to many hours
come on guys need to sell found another car please no more tyre kickers car is running getting it dynoed friday need it GONE! will take 12500 ONO Pm me or call dont miss this beast!!
hey guys car will be back on tuesday will post dyno power sheet once done, this car will blow you away with the ammount of power it has im really after r32 gtst manual 2 door plus cash my way come on guys need it gone im over autos time for a change
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
