These are genuine Takero's side skirts. They sit about 18cm lower than the bottom of your door. Ideal for a standard height Stagea wanting to get a lowered look but still legal or a lowered car wanting extra low. On my Stagea the front of the skirt sat 7cm off the ground. They sell for 60,000yen (about $1000) on his site. www.takeros.jp.
They have some everyday light scrapes along the under side but that would be covered once repainted to match your car. LHS has a scrape at the back - see photo. The underside corner has cracked along the bottom and will need a small repair (where the red arrow points to).
Located on the Gold Coast.
NO SWAPS for sideskirts but may consider others eg. CD or DVD head unit
Cheers.
https://www.sau.com.au/forums/topic/255587-stagea-sideskirts/
hey dude,ive got a genuine nissan/clarion TV/CD changer with a 6 inch lcd screen for sale on here.its out of my s1 stagea.will you consider a swap plus cash adjustment if necessary.and how much are you hoping to get for the skirts?cheers
rodders
rodders
Is it TV only? ie. needs a separate cd/dvd head unit? I've got an old school double din unit now. I'm after a newish single din unit so I can fit guages above it.
Choco, rules are you must state a price.
:happy:
Cheers Ruby.
Looking for about $200 but open to offers.
Would consider guages too. After Oil Temp/pressure and air fuel
Edited by choco
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
