Item:
Toyo Proxis R1 tyres
NEW
Condition:
NEW
Price:
$800 ono
To Fit: (What car)
245 x 18 x 2
275 x 18 x 2
Full set.
Gold Coast, Can deliver to Brisbane or freight anywhere. Contact for freight price.
Contact:
0410697349
Comments:
Great Performance Tyre!!
https://www.sau.com.au/forums/topic/255803-toyo-proxis-r1s-245x18-and-275x18/
sorry,
245x40x18
275x35x18.
BTW, you dont want a brand new genuine nissan lower front lip for the v35 do you? I have one.
any pics of the 275 please mate,and whats you best price to my door in melbourne?
cheers.
Im very interested in the full set and can pickup.
Only prob is they are slightly bigger than what i have fitted now (265/35 235/40) so have to check clearance .
I will be back down on the goldcoast wed if u want to pm your mob num i will talk to you then .
Regards
Trev
not willing to separate.
I will take some pics and work out the freight for you.
cheers.
i know mate,i didnt mention to separate 2 tyers :laugh: ..just wanna see how fat r the 275...
cheers mate..
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
