Hey everybody,
Asus N10JC - 3 months old. Purchased for my holiday in December - But never got to really use it. When used, was plugged in, didn't need the battery, but was plugged in.
Selling, due to requiring a larger one for uni.
24 Months Warranty - Receipts will be included.
Still has all protective cover (See pictures), i have all original paper work, cds, everything unopened.
No scratches, not dents, some slight blemishes on the chrome for some reason (see pics), keys have a bit of use
10.2" Wide Screen
Intel Atom 1.6Ghz
160GB Hard Drive
1GB Ram
**Nvidia 9300M GS 256MB Graphics Card
1.3Mp Webcam
XP Home - I just updated to Service Pack 3
Finger print scanner - I never registered my fingers - protective sheet is over it still
Extras
Purchase for $65 - LowePro 12" Case for it - will give
Samsonite skin - will give
More info can be found here: http://www.asus.com.au/products.aspx?l1=5&...amp;modelmenu=1
Price - $950
Pick up brisbane
Postage can be organised through Aust Post, medium box - $20 or so. + insurance if you want.
Pictures:
Edited by Owgasm
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
