hey guys i got a 32 skyline its black with a glitter through it pretty gay but looks ok... was painted about 3 years ago..
it is sittin on 18 inche white wheels with new tread al round..
been lowered with coil overs in rear and not to sure about front...
lookin more for a swap to see what i can get for this thing or just throw us an offer it had 10 months rego aswell with 165.00kms always serviced with brand new clutch drive perfect...
pretty standard interior just got head deck 6's in door and 6by 9's in rear runnin off amp and a 12inch sub in boot..
goes well for non turbo and perfect for p platers..
just pm on here or call me my number is 0435035067
thanks
p.s lookin more for swaps but throw me some offers
https://www.sau.com.au/forums/topic/256471-eoi-p-platers-dreammmm-32-na/
i have 96 vs commo stock auto, subs head unit, pod filter 18X,XXX
would make a cash adjustment your way
new rego
adelaide
just throwing it out there not expecting much
trying to find a na 32
where bouts in nsw you at?
  • 3 weeks later...
  • 1 month later...
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
