Hiya Jez,
Nice looking R32! It dresses up the estate where you live as well!
Keep checking NSW > Events and the cruises will pop up!
The Putty Rd one will come on again later this year. Quite a few gather for that!
Meanwhile if you have a full day to yourself you can do...
Albion Park > Macquarie Pass > Robertson > Kangaroo Valley > Cambewarra Mtn Rd > Bombaderry > Berry > Kangaroo Valley Rd > Kangaroo Valley > Robertson > Jamberoo Mtn Rd > Swamp Rd > Albion Park and back home and then no-one can shut you up for weeks!
Love the front lip!
Hi Jez...nice car mate top stuff...the N1 headlights set it off nicely too.
The lip is a Garage Saurus item and is the same as the one on my car...but looks better on your car in all black.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
