for sale
vy ss ute 2004 series 2....immaculate
70000kms w/- full service history and log books
GT40/88 ball bearing turbo
19" 5 spoke dished rims gunmetal/chrome lip
Custom turbo kit on heated coated high mount manifold
front mounted intercooler
60lb injectors
custom billett fuel rails
turbo beanie
Comp cams heavy duty valve springs
black ss leather interior
chev emblems
custom fuel system with pro flow fittings
billett custom surge tank
bosch external 700hp fuel pump
secondary high flow fuel filter
stainless headers
screamer pipe
tial external waste gate
turbosmart Fuel pressure regulator
lots of $$$$$$$ spent
vehicle has done less than 5000k since professional modifications
genuine sale
no tyre kickers or test pilots
$32k
for more info call 0406 566 344
adelaide metro area
will consider trade for vx -vz wagon v6 plus cash my way....nothing silly
Edited by sfearo
for sale
60lb injectors
turbo beanie
chev emblems
stainless headers
screamer pipe
genuine sale
$32k
for more info call 0450702601
adelaide metro area
MUST SELL PRICE DROP 30k neg...
for sale
60lb injectors
turbo beanie
chev emblems
stainless headers
screamer pipe
genuine sale
$32k
adelaide metro area
also car comes with all standard parts except exhaust system :blush::D:D
for sale
60lb injectors
turbo beanie
chev emblems
stainless headers
screamer pipe
genuine sale
$32k
adelaide metro area
also will sell cheaper with out 19 inch rims can come with standard 17" s pack/storm v6 style sleeper rims
for sale
60lb injectors
turbo beanie
chev emblems
stainless headers
screamer pipe
genuine sale
$32k
adelaide metro area
for sale
car makes 365kws at the rear wheels on just under 10psi boost with rich afr :blush:
lots of other stuff done to much to list incl.....new button ceramic clutch and billet fly wheel ...car done less than 5000k with turb kit..
60lb injectors
turbo beanie
chev emblems
stainless headers
screamer pipe
genuine sale
$32k
adelaide metro area
Edited by sfearo
must sell make n offer guys :thumbsup: 28k without 19" hp dished rims will come with vy storm rims...
for sale
60lb injectors
turbo beanie
chev emblems
stainless headers
screamer pipe
genuine sale
$32k
adelaide metro area
Edited by sfearo
respect! its good to see there are still some car modification enthusiasts out there with enough balls to bolt a turbo onto a V8 any idea of hp figures?
cheers mate :banana: 10psi with ls1edit.....made 365kws at the rears :D
  • 1 month later...
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
