Some of you may have seen them at the cruise, but if not i just got New Rims and tyres, my last tyres were some shity "nankang" brand, still the rims and tyres are in ok shape, so can smoke them up later haha
Got the Rims, Tyres + Major Allignment @ a place Called Emerald Tyres, in Joondalup - They are very good, as we Have used them for previous car, and can get in almost any rim you need, Speak to Damion there, Great Bloke :(
Not the Greatest Picture but you get the Idea
I had 235's all round B4 Kerb attacked me :D, It now Has 235/40 on the Front, and 245/40 on the rear, With Good Quality Kumho tyres all round.
Rims are "Speedy Wheels Inferno's With some Stagger Option on the Rear's for a deeper Dish"
Oh and was Bored today so i stripped out all the plastic/fury stuff from boot as it had acid Stains all over it from battery leaking also ate away at the thin piece of board covering spare, And Sprayed it all Up, Looks Much Better now, Couldnt find the smaller lens for Camera so this is the best shot i could get.
Edited by Stealthed
https://www.sau.com.au/forums/topic/258199-new-rims-wheels/
18x8 fronts and 18x9 rears??? Yea thats same as mine, and yes its that Old Bridgestone place, Just behind that new Fantastic Furniture
Edited by Stealthed
https://www.sau.com.au/forums/topic/258199-new-rims-wheels/#findComment-4439876
$2000, all up, They looked after me :blink: So i recomend going there if you need rims and tyres because i Went to Ian Diffen, they were to slack, didnt really help, and Bob jane was way overpriced, Emerald tyres Took good Care of me and the car!!
Edited by Stealthed
https://www.sau.com.au/forums/topic/258199-new-rims-wheels/#findComment-4440322
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
