Ive been thinking about doing this for a while. As much as i love this car it didnt turn out to be big enough and meet our needs. I have found a new car i want so i am selling this now. If it dosnt sell here then i will trade it in, but i would rather sell it to someone who will appreciate it.
I have to say now this is not technically a "genuine" 1999 series 2 Autech 260RS. I baught a genuine one in Nov 07 and had the motor rebuilt etc etc. The car ended up failing complience due to some rust and it taking longer then 12months to get to the complience place due to a dodgy panel beater taking 7+ MONTHS to do a weeks work on the car. Please give me a ring regarding this so i can explain it more.
We got the car back and then baught another stagea with a blown motor and swapped EVERYTHING over. So the only non "genuine" autech bit is the actual shell. The car is licensed with RB26 etc.
All the mods and parts have travelled less then 5000km's.
The vehicle's details are:
97 stagea shell
RB26DETT
Arias pistons
Eagle rods
ACL race series bearings
Fully balanced everything (crank, rods, flywheel, clutch etc)
Crank work (crack tested linished etc)
Block work (acid dipped, decked, crack tested)
N1 pumps
Tomie oil restrictor
Tomei sump baffel
Trust MHG
Trust 264deg cam's
All new genuine gaskets through out
New timing gear throughout
Head fully recon'd (lifters set for cams, guides etc)
New engine mounts, Gbox mounts etc
Platinum plugs
2 x Garret GT2860-7's
Apexi PFC
Turbotech bleed valve
HKS pods
HKS tuned length front pipe
HKS catback
Stock dumps and GTR cat
New belts
Cleaned stock injectors
Walbro in tank 600hp pump (not fitted but supplied)
Driveline:
New excedy cerametalic single plate clutch (rated to 330rwkw)
All 260RS driveline: mech diff, autech cradle etc
All new oils etc
Brakes:
New Master cylinder
Factory Autech 260RS brembo's
New Project Mu B spec pads
New rotors all round
New brake fluid
Suspension:
Nismo struts
Front Cusco castor arms
Rear camber arms (not fitted but supplied)
Hicas breaker bar
Exterior:
All factory Autech 260RS bodykit
Factory Autech rims with new Kuhmo ecsta sport KU31's
Fully tinted
new windscreen
Factory HID's
Interior:
Full autech interior
Trust turbo timer
Clarion CD player (dosnt work that well)
Alarm and central locking
Air con just regassed with new reciever drier
factory privacy blind and net
Car made 304ahwhp @ a little under 10psi. Limited by the stock fuel pump (hence the new walbro). Car was tuned at X-speed. They said with the combo on the car with the new pump, EBC and bigger injector you should see 450-460awhp @ 20psi ish, safley reliably, easily and responsively.
OK the bad points about the car:
Needs a new engine fan ( i have another 2nd hand one to go on that isnt cracked)
Radiator needs a clean out (got hot on the dyno but dosnt get hot now driving normally)
Needs new sway bar link bushes front and rear
Needs new castor rods bushes or just fit adjustable castor rods
I will sell the car with ALL the spare parts i have left over (except the busted RB25). PLease check this thread to see what there is, nearly 3k's worth of parts.
http://www.skylinesaustralia.com/forums/St...ts-t258504.html
I am asking $35000ono as is with all the spare parts.
Im located in Bunbury WA
0419943997
The engine work and all the new parts cost me well over $20k. And like i said its all done less the 5000km's so barely run in. I just dont have the funds to finish it (building a new house) and like i said its not really big enough for us (we have 2 kids and a dog).
I will get some pics up as soon as it stops raining.
https://www.sau.com.au/forums/topic/258643-autech-260rs/
Forgot to put in that all the engine work was done by Gavin Wood Autotech on the Goldcoast. I have a reciept for the work. And have receipts for most of the other parts etc.
Not interested in swaps unless you have a Jeep Unlimited Rubicon or a newish 4x4 dual cab.
https://www.sau.com.au/forums/topic/258643-autech-260rs/#findComment-4446499
Took some quick photo's today. Sorry for the car being filthy havnt had time to wash it yet. When i finish work next wednesday i'll wash it and get some better pic's.
https://www.sau.com.au/forums/topic/258643-autech-260rs/#findComment-4447978
Bump
Have just fitted:
ISC 52mm alloy rad
Front adjustable castor rods
Rear sway bar link bushes and new links
New engine fan (well a 2nd hand one but not cracked)
Also done coolant flush and full service, so basically fixed everything that was wrong with it.
https://www.sau.com.au/forums/topic/258643-autech-260rs/#findComment-4501586
  • 3 weeks later...
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
