SORRY ABOUT IT BEING INDY WEEKEND BUT THERE WAS NOT OTHER SPACE THIS MONTH.
When : 25th October
Time: 6:30pm - 11:00pm
Where : Kingston Park Raceway.
20 Mudgee Road, Kingston
30mins From Brisbane
25mins From GoldCoast
1hr20mins From SunshineCoast
NEED : Minimum Of 24 People Lets Make This A Big One.
Invite : R31SkylineClub QLD, SAU - QLD
Details - Will Need To Know What Level Of Racing Level 1 or 2, Level 2 Is The Longer Session
Price : Level 1 : 60$ pp
Level 2 : 70$ pp
We Need To All Be Doing The Same Level - As This Is Structured As A Team Even , Say if we get 80people there are 16Groups of 5 and each person gets a role in the team - driver, 2 co, drivers, crew etc. this then rotates untill each driver has completed their level (ie : l1 = 2x18 laps l2 = 3x18 laps).
We Will Have The Track To Ourselves And there Are Plenty Of BBQ's To Bring Meat And Stuff Along, for those who have youngin's under 16 there is other stuff for them to do, mini golf etc.etc. ?!?
The Karts used will be the Pro Karts (97km/h topspeed).
Confimation NEEDED by OCTOBER 21st (Monday)
We Can Make This A Competitive Event And Pay An Extra 50$ and Get 1st,2nd,3rd Trophies - This Cost We Could Split As A Group And Well The People That Take Out Those Places Will Be Able To Get Something To Remember The Nite With. This Will Also Promote Socializing With Other Club Members "Mark THIS ONE OUT IN YOUR CALENDER AND COME MEET AND GREET THE OTHER MEMBERS"
The Details Are Finalised, Please Forward Confirmation To : [email protected]
Just So We Know Who Will Be There, As We Need To Have Definate Numbers To Make These Type Of Days Go Off, And Give Us And The Members Discount And A Fun Day Out For The Family Children Over 16 For Kart Riding.
Regards,
Ashley Neal.
Sorry Guys This Has Unfortunately Had To Be Cancelled As We Didn't Get Enough Numbers, Due To The Time Of Year Being Close To Xmas And All, Will Look At Re-Schedule It For Early Next Year After Xmas :P
Regards,
Ashley Neal.
Hummm I did all the ground work etc. i'm sure i mentioned that i needed all confirmation by 14th as i have to come up with deposit for the track on the 17th, and i have had not much response other than it is a bit expensive at the moment, which is understandable.
No Doubt I will organise another one for the 31 club or what have you. but i'm sure Slip, may be able to organise something..
Regards,
Ashley Neal.
I'm just being safe as i have no trouble to pay the deposit, its just i don't want to have to pay for everyone that doesn't show up for the evening, as i'm not that financially well off, to do that for the both clubs, Sorry guys.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
