Black 1990 180sx with Sil80 conversion (210 RWKWs)
SR20det red top
Z32 300ZX 5 speed manual gearbox
Z32 AFM
Nismo Adjustable FPR
OS Twin plate clutch
Trust alloy sump
Power FC with hand controller
Solid gearbox mount
Custom tailshaft
Nolothane rear bushes
Oil cooler with braided lines
Battery relocated to boot in battery box
Trust intake pipes
Stainless dump pipe with flex pipe and full blitz exhaust
Pod filter
S15 injectors
ASE intercooler kit
Big alloy radiator
Alloy overflow
Alloy gearknob
Aftermarket clutch line
Apexi turbo timer / boost guage
Clarion stereo system
Dish steering wheel
GTR rear swaybar
BRIDE drivers seat
Signal catch can
5 stud conversion with R32 front brakes and R33 rear brakes
Hydro handbrake
Alloy steering spacer
flared n rolled rear guards
Tein steering rack spacers
Tein tie rods
Tein tie rod ends
Stern 17 x 9 and 17 x 8 wheels
Walbro fuel pump
Cusco mechanical 2way diff
Type x tail lights
Top of the range JIC FLT2 coilovers
D-max adj castor rods
Cusco adj rear camber arms
Front and Rear strut braces
Alloy / Nolothane pinapples
2 year old S15 T28 turbo and braided lines
Bolt-on spacers x 4
Probably more I cant think of right now.
PS: Wheels pictured have been sold and will now come with 17 x 9 and 17 x 8 sterns, enkies or SSRs...
$12K FIRM
  • 3 weeks later...
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
