Ice cream meet was good.
Didn't get sicker from Dave either. Feeling much better today.
thought I was getting a sore throat this morning but its just from the air con in the office i think. Feel like another one of those milkshakes now. I'm off to lunch, Toscany's steak sandwich mmm
Hey Funky this is the car I was telling you about last night. 18 x 10.5 + 18 all round. Absolute sex on wheels. I think all that had to be done was the guards lipped. Would die happy if my car looks this good one day :)
Going to ERD on Tuesday for a service so I'm going to talk to Dan about the Bilstein/King Spring combo he has. I've been on the waiting list for them for a bit over a month so they should be close now :D Wheels arrive on the 7th of May fingers crossed.
These are the ones I've got on order :)
fap fap fap
yarrr here be the wheels that i just got for my 32:
19x10 +13 and 19x11 +7
mmm gonna get raped when it comes to fitting tyres tho :)
hopefully 235/35/19 in the front and 275/30/19's in the rear. they're the cheapest sizes I can get. They'll be a little bigger than stock wheels (20mm bigger overall) but I should be able to compensate my speedo to adjust, and the widebody will hopefully mean it won't scrub.
Gonna be getting the centres powdercoated (or at least painted) in black. Should look good on satin black car. Leaving the dish polished. mmmm and gold rays nuts to go with the gold GT badges and shiz.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
