yeah, he didn't buy a 32...
funky you know the drill... Pics or BAN !!!
as for smithy, f**k man those results are rather depressing.
150+ is what u want, 140's at the lowest. And within like + / - 5
hope you got cash, she'll have to be cracked open... :D
seeya @ 6.
I even took the R32 out and you f**ks werent at BnR :(
what!? look at the time you posted..
pm me your msn contact detials or phone number i was saying where is nismo!? d00d should of been here by now and it was around 7+pm!
lol about time someone brought an SR that inspired awe rather than the limpdick boat anchor that Redsuns drags around in his 180.
Hey this is Alfred, just want to say many thanks to everyone that helping me tonight and really sorry to the R32 that i bump into. (Fxxk Why you suddenly stop!! haha kidding) Hope your car and my car will be fix asap so we can back to the crew.
Thank you everyone for help!!
hahah Yeh I got there at like 8pm.
I'm fashionable late, always.
