yo yo yo
just got my two quotes,
it seems that the spacesaver saved my boot from caving in further - so the thing is f**ked
first guy said 6-8k for the repair,
and the 2nd guy said around 8k - possibly needing a rear cut..
fuuuuuuuuck!
Get old mate to just buy you another car
Aslong as you dont install some hectic chromies with perfect narrowbody fitment we should be sweet.
Track car ftw :) Wish I could afford another one. Best I can afford atm is a 31 or something. We'll see in december :P
1. I don't like chromies.
2. I hate people that put body kits on there car and they can't lower it where the wheels are in the guard, hence buying a Nismo kit for it that is the same height as the stock kit :P
And 31's are awesome! (I use to have one)
Edited by MYY34
8k is only 2/3 of the value of the car so you might get it repaired. If not just hope they give you the whole 12k n buy another one
yo yo yo
fuuuuuuuuck!
jeez how annoying.. didnt think it was that bad though, isnt $8k a little overpriced?
basicaly what you need is a rear bar, a boot lid and straightening out the rear end..
now the first two items you can get for less than $1k?
yo wolf!
man wat we didnt see the other night is that the whole boot floor as crumpled..
the 8k was only an estimate - we'll find out more in the next few dayss..
It'll be cheap if you source it yourself definately but if you're letting someone else do the job its an entirely different story. First they will get all brand new geniune parts, second mark up 30% 40% (just look at my charge rate at work... 135/hr to client)? And third, their time/contacts. These would make your 2-3k job easily 5-7k. But I do agree 8 seems unreasonable.
If I were you... try to get the full 12k and save the rest up and get a GTR ! I pack my lunch/cook dinner for more than a yr to get mine =P
brandon you car is amazing - but its 4wd!
im a man of my rwd hahaha
ill straight swap you though :P
Its a good deal Brandon. Tristans car does epic skids :P
I dont think 8k is unreasonable. It would be a fair amount of work to straighten up the car properly and things will always come up which are unexpected. Its probably a 6k job but the guy has given himself a buffer.
PS: GTR + RWD Mode?...
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
