Any of you gang bangers doing exciting shit this weekend
Was thinking about trying to fix the Daewoo... kinda not in the mood though...
Anyone going to tas's workshop? gonna head there soon to check it out.
Why? What's happening there?
well hey, if you want to buy me a line so I can drive that to meets instead of the Daewoo that'd be awesomepossum. If not, guess I'll have to keep waiting until I can get one, and be one of those... whatdayacallem?... enthusiasts?
Bringing a Daewoo is about as lame as me driving my Volvo to meets.. Oh wait. I did :happy:
I kid I kid.
and u let it hit the limiter lol!
<3 John
its all jokes breh
yea its true everyone here pussies.. watch them talk it up pretending not to be :mad:
brandon came and left cause his a bitch.. as i ahd a customer waiting so i couldnt really chat :happy:
You know im kidding right.
Buy my shit box. $7k
I said BUY me one.. not SELL me one... slag :happy:
Hey John where do you live?
around the corner from Taz's workshop
why does my clutch pedal squeak?
if being srs, oil the hinge
Edited by Isola
Dodgy bracket, flex, dry spring.
My old car did it bad + flex, welded it up perfect! Current car does, but no flex, read on here a few times just load it up with WD40 etc and it should help
yeah i will give it some WD love tomorrow, then finish bleeding the brakes and i can drive it again :happy:
booked in for an epic expensive wheel alignment on thursday (getting the rear control arms bent to adjust camber)
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
