Siff run a cat anyway.
Keep dave away from breaker bar's :)
His man arms are too grand for baby bar's :)
lerl, gona hit up the paint and blasting shop today, get the rest of the painting requirements. still on for tomorrow josh?
Still on for tomorrow, just let me know when and I'll rock up
Change of plans sweet pea, got an interview in the CBD tomorrow, trying to make it in the morning, then I'll come from the city to you place with a change of clothes.
Will let you know on msn later..
sif that!
i would still rock what evers in that pic
hmmm lip kit... *ponders*. :thumbsup:
lip kit! f**k yeeehh
there is a guy i think its sedan-gtst (not sure on user name)
but hes in vic with a white 32 4door and he has a sick lip kit on his front bar
ill find picturesss
quick nismo push F5!!
anyways wheres that place you was talking to me about making CAM's approved half cages?
also thinking of what suspension arms to get... thinking kazama.. or maybe sourcing 1 or 2 parts from ikeya formula
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
