Lucky ive got a smokin hot wife :D
Pics or ban, dunno why no1 else picked up on this. "pics or ban"
Woah... 250bucks for a helmet. Might have to postpone it till next month then. Feeling super guilty for spending this month already. Sheez.
250bux is cheap as for a helemet.
And no a motor-x Helmet is not the same, despite the muppets who wear them.
They are built to withstand different types of impacts
im a muppet like that, use my old mtb downhill fullface, not even moto rated. lol (its carbon tho, epic lightness)
i've never seen his room :banana:
you will :( lawl.
got home early did some work, got another coat of black to cover all the spots i missed, then started with the (stone chip / body deaner) i figured id do the whole underbody as it would most likely get some offroad use at the track :)
"dudemans"?
errrr??? :banana:
yeah i was exited about comin home and got a bit carried away :(
WHORES! you sicken me.
nav_m.gif Today's Top 20 Posters Member Joined Total Member Posts Posts Today % of today's posts
Danski 2nd May, 2009 561 43 3.26%
astrotristan2 2nd August, 2009 390 25 1.90%
Nismo_Boy 31st May, 2002 17,204 17 1.29%
lol!
top 3 posters of the day so far hahah
Just goes to show how little I did at work thismorning :)
you will :banana: lawl.
got home early did some work, got another coat of black to cover all the spots i missed, then started with the (stone chip / body deaner) i figured id do the whole underbody as it would most likely get some offroad use at the track :(
HAHA, cant wait.
Getting closer dave "dudeman".
dave if u didnt have so much stuff you'd have like 7 undercover garages :banana:
tehehe
hahaha, take it up with my old man. Not long now till i move it up to the top garage. I wouldn't want my orange cage getting wet :( hooray stopped raining.
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
