going to have a look at a 31 on monday after Martins hot tip. Apparently it needs a new left wing, front bar and grille, headlights and a cat. He says hes not selling his rims with it so I'll have to find some stockos if he can't find any.
Anybody got a car trailer or know how much it would cost to get a car trailered from Church Hill to Jimboomba?
hey everyone, just finished working on the car today - 7:30 till 6:45 and i still havnt had lunch yet, so f**k :) the people who give me grief about when my cars gonna be done.
pics:
hey man, sounds good.
i can do u a deal on 4 rims with the 20 setup :) inc tires. i towed my car home from nsw, cost me a deposit off 200bux at kenards but 24hr hire was 120bux in the end, was a good trailer and very nice to tow with, dont bother with servo trailers. otherwise ring up a tow company and ask em how much per km.
dude i have 4 17" chromies you can have
even some random mismatched tyres to throw on
Edited by Smity42
i'll raise you martin and put up for offer my fully sick 18'' chromes... lol
yeah josh we are still on. seeya laterr
Edited by 32_Dave
lol makes me appreciate how awesome my parents are lol. Do whatever I want lol most of the time Dad wants to help. Offered to get another shed when I said I wanted a track car lol.
Can he build me a shed?? I need another one.
I just don't ask :)
I just tell now. It works better in the long run.
so car is running like a dream..
cbf putting the oil cooler on.. :)
handles like its on super rails now..
:nyaanyaa:
but they f**ked the wheel allignment today
guess time to book it on monday..
:) ill destroy you guido :)
You better!!!
Why do want a 31?
P.S. Lakeside is a f**king awesome track
Yes, I can't wait to have a hack at it.
You better!!!
Why do want a 31?
drift pig :bunny:
im heading to the gap tonight lol :bunny:
and josh i <3 your piggy lexus
post the pics where you got owned by the speed bump
I used to roll gutted haha
Belly up at SAU dyno day; there are vids on here of the dyno runners using jacks to get the stupid thing back out of the work shop haha
The fuel pump works dave, but when the T88 comes on boost around a corner the clown of a car surge's, still more sorting out. Going to throw on that one way valve (tech threads on here seem to think they shit out from time to time).
Might go buy wire and go nuts with earting the pump better too; saw a few tech threads re that as well.
what your missing out on?
close up of the filler primer, gona be sexiii !!
Id rather be sanding and knocking back rough spots than chasing ghost elec problems!! Seems to have fuel, but almost like an elec cut/short. Oh the joys of dionogistic work.
Time to reset the ecu... again
Let run in the shed for 15-20mins after replacing little valve, all was seeming to be ok; then BAM rarp rarp rap rough as guts and stall.
Hard to start; started left run for a bit and it seemed fine. This car is the devil, I wish not to test drive it.. just yet haha
your still missing out... needs sanding fix your shit !!! lol
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
