going to have a look at a 31 on monday after Martins hot tip. Apparently it needs a new left wing, front bar and grille, headlights and a cat. He says hes not selling his rims with it so I'll have to find some stockos if he can't find any.
Anybody got a car trailer or know how much it would cost to get a car trailered from Church Hill to Jimboomba?
hey everyone, just finished working on the car today - 7:30 till 6:45 and i still havnt had lunch yet, so f**k :) the people who give me grief about when my cars gonna be done.
pics:
hey man, sounds good.
i can do u a deal on 4 rims with the 20 setup :) inc tires. i towed my car home from nsw, cost me a deposit off 200bux at kenards but 24hr hire was 120bux in the end, was a good trailer and very nice to tow with, dont bother with servo trailers. otherwise ring up a tow company and ask em how much per km.
dude i have 4 17" chromies you can have
even some random mismatched tyres to throw on
Edited by Smity42
i'll raise you martin and put up for offer my fully sick 18'' chromes... lol
yeah josh we are still on. seeya laterr
Edited by 32_Dave
lol makes me appreciate how awesome my parents are lol. Do whatever I want lol most of the time Dad wants to help. Offered to get another shed when I said I wanted a track car lol.
Can he build me a shed?? I need another one.
I just don't ask :)
I just tell now. It works better in the long run.
so car is running like a dream..
cbf putting the oil cooler on.. :)
handles like its on super rails now..
:nyaanyaa:
but they f**ked the wheel allignment today
guess time to book it on monday..
:) ill destroy you guido :)
You better!!!
Why do want a 31?
P.S. Lakeside is a f**king awesome track
Yes, I can't wait to have a hack at it.
You better!!!
Why do want a 31?
drift pig :bunny:
im heading to the gap tonight lol :bunny:
and josh i <3 your piggy lexus
post the pics where you got owned by the speed bump
I used to roll gutted haha
Belly up at SAU dyno day; there are vids on here of the dyno runners using jacks to get the stupid thing back out of the work shop haha
The fuel pump works dave, but when the T88 comes on boost around a corner the clown of a car surge's, still more sorting out. Going to throw on that one way valve (tech threads on here seem to think they shit out from time to time).
Might go buy wire and go nuts with earting the pump better too; saw a few tech threads re that as well.
what your missing out on?
close up of the filler primer, gona be sexiii !!
Id rather be sanding and knocking back rough spots than chasing ghost elec problems!! Seems to have fuel, but almost like an elec cut/short. Oh the joys of dionogistic work.
Time to reset the ecu... again
Let run in the shed for 15-20mins after replacing little valve, all was seeming to be ok; then BAM rarp rarp rap rough as guts and stall.
Hard to start; started left run for a bit and it seemed fine. This car is the devil, I wish not to test drive it.. just yet haha
your still missing out... needs sanding fix your shit !!! lol
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
