Cars stalling in public is not nearly as funny as one would think.
It would appear you are smashing the engine bay; I need me a farking Console, something is a little astray me thinks
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
