I have your mother next to me
Oh snap
when in doubt, cup
follow young olivers example, minus the bowl
Haha hes goin for the double.
edit - check out the look on his face . . . lol
its a look of a man who is determined and prepared for the job at hand.. (or hands as the case is in this situation :happy:)
oh boy i wish i could do photoshop hahahaha :ph34r:
DAMMIT!
READ MY MIND!
ohk if anyone can photoshop - can we pls get a pic of dan and put it on instead of olivers...
and maybe do something about the bowl - LOL!
hahahahhaha
DAMMIT!
READ MY MIND!
hahahahhaha
lol fuuuuuuuuuuuuu
started any work on the beast today? ebc in?
lol at my front yard now, its a spare parts yard :blink:
carbon = delicious
ps thought of the best sticker idea for the dash of epicly sick cars - i'll pm you
3rd gear *jizz*
and yeeh - no need to boost her yet, im still trying to pick up my nuts from stock boost, i just thought u were going to do it so shes ready for when we man up hahahah
BEAST
"bro do the speed limit, its 80km/h, ur going like 70ish"
"err tristan we're doing 120"
"f**k."
rofl... yea its so f**king nice..
should of seen me on the way to work today.. i laugh at people who think they can push in just because im driving it low rpm..
had two cars that pushed in and try to speed off.. when i tried to merge into that lane today..
was curising in 3rd... thought.. hmm.. CHOP CHOP!!! 2nd gear pull
did you do the Tak arm on the window and your head resting on your hand and driving with your left hand only
..you know what i mean
oh we are... we are..
Team Wraith
mauhahahaha :blink:
u should see my rear bar.. :blink: has a rear bar like colins.. epic carbonified
3rd gear *jizz*
BEAST
"f**k."
Pics or :down:
its not all about looks, what about being stealth? :blink:
but you'll soon find out what my number plate is and what my rear lights look like :blink:
with the current situation for danski at the moment astro..
you most likely will have to do it outside his house rofl LOL AHAHAHA
HOHOHO
I cant wait to rape you both in that "car"
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
