Made a new website image for Tas:
Credit to John for the idea
bahahahaha*takes breath* hahahahhahaahha. Need to add some rocker stoppers :ninja:
oh i see how it is,
how about you go get some coilovers for your 31
OOOOOOOOOOOOOOOOOOOOHHH thats right - no coilovers for 31s.. too old
:D
S13 coilovers + Cusco 31 camber tops = 31 coil overs...
P.S. Got a little worried searching for "Box" in google images at work. Turned out OK but, safesearch was on :)
Safesearch ftl lol
lol
R31 FTL :)
Look! I found a picture of your 180 at the drags:
Its got a good 40 sec pass in it for sure.
sorry i will say something, im just trying to translate what the pom is saying...
:ninja:
It's alright lots of emos struggle with english. Would it help if everything was in poem form?
what about that epic r31 i found ages ago martin? ima going to try find it againn
I have a really awesome pic of that number 12 GMS car at home as my walpaper, but for the life of me I can't find it again here
Edited by Smity42
my orange is so teh sex
ur just upset that i can pull 10ton bitches while ur car sits on bricks with rust :) more rust then dave!
Fixed.
I think you might have been lead down the garden path there with the size/quantity thing Tas
Edited by GTTG
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
