tres accurate
Ok thanks John... so going through carwash is still ok though? Just means getting out and hand drying after?
Or should I do the bucket/car lovers manual clean?
I just had a bottle of coke, from a GLASS BOTTLE
win
QFT :cool:
Oh yeah how's everyone's cars?? Still haven't washed mine, I was told if I wash it I should dry it straight after with a chamoi (spelling?) otherwise the fine dust that's left on my car + water might eat/scrape my paint.
No idea how true that is or if the dude from the post office was just speaking out his ass!
Tis true. Rinse, wash with no overlapping strokes, rinse again, dry with chamois, wax if you have it.
My car was extremely sexy last night but tis dirty again now lol ;)
like they haven't been watching for years... :)
ooooooooo that totally trumps the mcdonalds one. i'm gonna do the same! i'm getting gravy though. kfc sauces are shite.
Yeah Gravy > all. I think I might get 10 nuggets, box of popcorn chicken and 6 crispy strips + a large potato and gravy. maybe some chips as well.
good luck with that
I know what I'm gunna do now :)
quote limit :( tried the other day for an epic "that's what she said"... got denied :(
tres accurate
Yeah quote limit sucks anus.
you talking about the quote button or your shitty macro. for Multi Quote fun you have to hit Add Reply not Fast Reply after you click on all the quotes you want. Class dismissed.
Chocolate Milk FTMFW
:D
Who wants to do lunch?
I'll do lunch :D
I'm definitely getting 40 nuggets for dinner
I raise you another 20. 60 nuggets!
Awesome stuff :cool:
Tastes like Tristian, wait, what.
Josh caught the gay
Car wash will scratch your paint worse than pretty much anything. Apart from the broom shit thing at carlovers. DONT USE THE BROOM.
No. 999 Bitches Cherish it.
where?
Just get a good quality chamois and don't use brushes/scratchy things on your paint
I'll do lunch :cool:
1. sounds good
2. where? i'm more than likely in for lunch, brah. but where are you going?
6 months and still havent cleaned it.
in the 18 months I've had the 'woo I haven't cleaned it. hosed it a couple of times so i could see out the windows, but apart from that, nothing.
load bearing/structural dirt FTMFW!!
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
