Josh seeing as though your such a fountain of knowledge today . . . IYO whats the best place to get a 3"cat (doesnt matter about highflow as im just gona gut it anyways) and a set of adjustable camber arms for the rear of the 34?
thought you didn't want a cat?
Ebay/boost/SD/SAU for a 3inch cat... I mean by all means buy a new one and gut it, or just pay bugger all for a 2nd hand 3inch one. There are rubbish 3inch cats (new) on ebay, that blow the core out pretty quick, maybe just pick one of those up... Not that Im condoning a gutted pussy.
Pretty sure Taz was able to get arms?? Both China and none China. Whiteline Rear arms are cheap these days too.. I am a big fan of some of the Australian made arms at the moment..
If you have the budget, ikea formula no questions asked.
oh and 7weeks to do timing belt and water pump and new thermostat..
ill be driving it tommorro wwhen the wheel allignment is done..
so we're on for tmr night, wraith?
I dont but I want it to look like I have one ;)
legalities maybee??
:D
Ok thanks ill check it out
No doubt.. As long as he sticks a bit of pipe through it, to stop turbulence inside the shell it'll be like not having one at all.
could not believe danski actualyl asked that question
its true.. EFI has brain washed him..
*sigh
thast right boy..sigh all you want..
i blieve i chatted with you regarding ur shit on thursday night..
when ur shopping trolly blew off a pipe!
My shopping trolly? ? ? I wish . . . .
@Dan yeah bro you don't need proper motor sport semi slicks since your car will never see the track. Those federal semi slicks or Khumo KU36's will be perfect for you, and much cheaper (y)
Yeah agreed.
Are they ok in the wet?
I had the kumho Ku36 on the rear of my other rims, they felt the same in the wet as the road tyres I had on b4 (useless....lol)
    • I have been wondering if this is as simple as a voltage issue with the battery. Even on a charger, I can’t seem to get it over 11.8V on the terminals.    Unless the alternator has failed as well, that wouldn’t cause it to die in the middle of driving though.
    • I’ll give this a shot next time I’m able to wrench on it.    I was able to get my hands on a Haltech Nexus, so that should help with some of the more bizarre troubleshooting. Make sure the CAS is actually sending signal and will be able to set the proper dwell on the R35 coils.    I’ve checked power/grounds/signals at the CAS, ignitor, and plugs and it was all there. Granted this was static with ignition on, not cranking.    I also plan on swapping out the fuel filter and throwing on a fuel pressure gauge at the rail just to confirm I’m getting the correct pressure at the rail. 43psi if I recall correctly.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
