2 packs of migs + 2 eggs + heaps of chilli flakes + cracked pepper = win
you're a stoner arent u
and if so, it needs more mayo!
fu*king jesus... I go to sleep for a few hours and it gets out of hand up in this bitch... cbf quoting everything so:
yes, totally
LOL
+1
LOL n00b
you're an idiot
show 'em who's boss!
mmmmm tiggs
yeah that's right bitch, take it all!
pics or ban
f*ck you kent
:D
you bet your ass
and let me finish by saying - aircon FTW
might start my training again tonight if i finish work early...
quite motivated after this vid
shit tas i didnt realise they were videoing me that night
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
