Hahaha @ unit ....
I also find the quality isn't as good with a "plug in" product lol!
I want one with a USB slot, I wonder if the quality would be the same =\
I think its all to do with the quality of cable you use .?.?.?
That could be it lol ... The iPhone doesn't sound as good as when I have a CD in, dammit! Might try a different cable!
Yeah my mate whos into all that shiz says you need audio specific cables to get the quality :(
USB and SD are fine. As long as you encode your MP3s correctly in the first place. If you have crap quality MP3s they'll sound shit no matter what you do.
Mine goes in through a usb cable and the mp3's are fine so it must be the cable ?
It's looking good Dave.
It's almost a roller!!!!!
I have 2 weeks off soon, when does your work hoils start?
not till the 23rd i believe maybe a bit before hand, but crazy busy atm 4 renos and a brand spanker to finish before Christmas
as for headunits get something that rocks USB and buy yourself a small portable HDD and format fat32 and you have like 80gb of music in your car :(
sweet ass notice f**ker :D
Dude I told you WEEKS ago. Don't make me go and find the post
I'm thinking I might go head unit/amp shopping today. Where's a good Northside store dedicated to car equipment?
Dude unless you want to spend epic cash, just go to JB or WOW or something. They all sell the same gear
Yeah, they're all iPod/iPhone crap at the moment :(
+1
I don't own any apple products
+1
Thinking it might wind up being eBay spec, because the big hitters at the moment don't seem to be making very good touch screen head units. Although, JVC have one that would be awesome if it had SD (fail on their part). And Pioneer seem to have lost the plot and started putting smaller screens on their units :)
*sigh*
Pioneer are shit these days don't touch them.
that's the root of your problem right there
+1
What bitrate?
as for headunits get something that rocks USB and buy yourself a small portable HDD and format fat32 and you have like 80gb of music in your car :)
As long the head unit reads a drive that big you're fine. You also have to make sure it can read huge file names and it's not going to throw tildes everywhere and make it a c*ntdog to navigate through it.
Witness
I wanted to use the car sound place as a living catalogue
Thanks for the heads up! They look like they're going Xplod style :(
Mangs..
I got a Pioneer AVIC-F310BT and it's awesome. So there :)
I've seen your unit. Needs more big.
Interpret that how you will :D
Edited by Isola
I have a Pioneer and it is shit :( LOL but it's like 1000 years old :) I've got like a mix & match stereo, hehe as I have a Alpine Type R Sub & 2 spider amps! Hahaha! I really need a new head unit =\
IF for some reason you feel you really HAVE to run a sub then - Boston G5 subs FTW
Real music doesn't need subs though :D
Edited by Isola
I see. There is one near my work HERE. Not sure if its any good as a living catalog but...
Yeah they are
f**king lol
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
