thats all jap
ahhhhhhh! I dunno... all asians look the same :D
Yep doing the day shift.
Its awesome. :sick:
Any work going there?
found out why skins loves to go drinking in toowoomba
LOL no way dude. Toowoomba chicks are loose and easy, and suffer from hallway hotdog syndrome. Much like a lovely lady we all know ;)
I like the way you think...
I'll let you know how they fired me on tuesday :)
See if you can get classes as an "unwelcome distraction" like I did!!
copgyf*cker
:D
Play nice.
I have a Cert III in water operations and 5 years experience as a water treatment plant operator. I also have 3 years experience working on a plumbing crew. For this job you wouldn't need a Water ticket but you would need to have a bit of experience working with pipes, prv's, valves etc. What they look for is someone who has experience in moving bulk water.
Or a mate who works on the inside who will give you all the answers.....
at a price
:sick:
MacGyver is cooler than any of you will ever be :):cool:
Martin - I bought this Kenwood unit :P:bunny:
Still looking for a good amp though. The car already has some MTX Audio speakers in it :banana:
Should I get a wiring kit? Or just buy some 0, 2 and 4 gauge wire?
hello hello,
just got home
it was f**king hot today - got a heap of work done on the 32 and 180 today however :banana:
It was hot!! Glad I was at the shops and or in an airconditioned house and car all day!!
What were you doing on the tractor? Smoke stack need polishing?
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
